TM1 Contributor - approval heirachy is being used
rollo19
Post by rollo19 »
.. by another application. Anyone else get this? I'm trying to deploy a contributor application and I get this error "The approval hierarchy is being used by another application."
Has anyone found an easy way to clear all Contributor history / start a new?
I have tried copying in a fresh TM1 server without the control objects, and also re-creating the tomcat application from the war file with no luck.
Looking at the server, those Contributor control object re-appear.
rollo19
Re: TM1 Contributor - approval heirachy is being used
Post by rollo19 »
Process tp_admin_delete_all cleans it up - thanks JW
David
Version: 9.4
Post by David »
JW,
I am new to TM1. Can you explain a little more details on how to run }tp_admin_delete_all?
David
rollo19
Post by rollo19 »
Display > control objects & you will see the process }tp_admin_delete_all, note the script deletes all the contributor control cubes & dims. Handy if you want to start afresh.
David
Version: 9.4
Post by David »
Hmm, I cannot find }tp_admin_delete_all at all
rollo19
Post by rollo19 »
Are you using contributor over this model?
David
Version: 9.4
Post by David »
Yes, I had created a contributor application using this model on the server. I copied the whole model to another machine and tried to created another contributor there, but received the error message. Thank you for your time.
DuangpornT
Version: 9.5
Excel Version: 2007 SP2
Post by DuangpornT »
It's a TI Process, pls move down at "Processes"
David
Version: 9.4
Post by David »
Thanks all. I found it.
