.. by another application. Anyone else get this? I'm trying to deploy a contributor application and I get this error "The approval hierarchy is being used by another application."
Has anyone found an easy way to clear all Contributor history / start a new?
I have tried copying in a fresh TM1 server without the control objects, and also re-creating the tomcat application from the war file with no luck.
Looking at the server, those Contributor control object re-appear.
TM1 Contributor - approval heirachy is being used
- rollo19
- Version: 10.1
- rollo19
- Version: 10.1
Re: TM1 Contributor - approval heirachy is being used
Process tp_admin_delete_all cleans it up - thanks JW
JW,
I am new to TM1. Can you explain a little more details on how to run }tp_admin_delete_all?
David
David
- rollo19
- Version: 10.1
Display > control objects & you will see the process }tp_admin_delete_all, note the script deletes all the contributor control cubes & dims. Handy if you want to start afresh.
Hmm, I cannot find }tp_admin_delete_all at all
- untitled.JPG (33.65 KiB) Viewed 8996 times
- rollo19
- Version: 10.1
Are you using contributor over this model?
Yes, I had created a contributor application using this model on the server. I copied the whole model to another machine and tried to created another contributor there, but received the error message. Thank you for your time.
DuangpornT
- Version: 9.5
- Excel Version: 2007 SP2
It's a TI Process, pls move down at "Processes"Hmm, I cannot find }tp_admin_delete_all at all
Thanks all. I found it.
