Tm1 Rules for string element
sairajsoma
OLAP Product: tm1
Excel Version: 10
Post by sairajsoma »
We can write N: right instead of S : for string element 'comment'
Re: Tm1 Rules for string element
sairajsoma wrote: Fri Feb 14, 2025 8:39 am We can write N: right instead of S : for string element 'comment'
So is that a question?
Or a statement of fact?
Do you have an issue with writing a string rule?
You can use N: it won't be a syntax error, but it also won't do anything! If you want to assign a string value to a rule calculated cell, then you must use the S: qualifier (and the cells in question defined by the area statement must in fact be string cells! Which means the element type of the last dimension must be S.) Oh, and don't feed string rules! Feeding is for consolidation. As text doesn't consolidate there is really no reason to feed a string rule, this just wastes memory and increases compute time.
As of now I'm confused what you actually want to ask.
Can you please write a proper question ?
Are you still working on the rules of November 2024 ?
viewtopic.php?t=16787
sairajsoma
OLAP Product: tm1
Excel Version: 10
okay got it. this was the full ques actually. thansks!!
Screenshot 2025-02-15 194427.png (197.4 KiB) Viewed 31071 times
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Post by Adam »
With threads like these, no wonder ChatGPT is suggesting CubeNext();
Take care,
Adam
Wim Gielis wrote: Fri Feb 14, 2025 5:16 pm
So Wim made a very reasonable request since your question made little, if any sense.
sairajsoma wrote: Sat Feb 15, 2025 2:19 pm okay got it. this was the full ques actually. thanks!!
And you responded with something completely irrelevant making even less sense than the 1st "question."
I don't think it's even worth directing you to the request for assistance guidelines. Some people can't be helped.
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
lotsaram wrote: Mon Feb 17, 2025 10:49 am
Man, I've missed checking the Forum on a regular basis. :lol:
Ty
Cleveland, TN
