Tm1 Rules for string element
sairajsoma
- OLAP Product: tm1
- Version: 10.2
- Excel Version: 10
We can write N: right instead of S : for string element 'comment'
- Screenshot_2025-02-14-14-06-05-72_f9ee0578fe1cc94de7482bd41accb329.jpg (359.97 KiB) Viewed 35483 times
Re: Tm1 Rules for string element
So is that a question?sairajsoma wrote: ↑Fri Feb 14, 2025 8:39 am We can write N: right instead of S : for string element 'comment'
Or a statement of fact?
Do you have an issue with writing a string rule?
You can use N: it won't be a syntax error, but it also won't do anything! If you want to assign a string value to a rule calculated cell, then you must use the S: qualifier (and the cells in question defined by the area statement must in fact be string cells! Which means the element type of the last dimension must be S.) Oh, and don't feed string rules! Feeding is for consolidation. As text doesn't consolidate there is really no reason to feed a string rule, this just wastes memory and increases compute time.
As of now I'm confused what you actually want to ask.
Can you please write a proper question ?sairajsoma wrote: ↑Fri Feb 14, 2025 8:39 am We can write N: right instead of S : for string element 'comment'
Are you still working on the rules of November 2024 ?
viewtopic.php?t=16787
sairajsoma
- OLAP Product: tm1
- Version: 10.2
- Excel Version: 10
okay got it. this was the full ques actually. thansks!!
- Screenshot 2025-02-15 194427.png (197.4 KiB) Viewed 33661 times
Adam
- OLAP Product: IBM PA
- Version: 2.0.9.x
- Excel Version: Microsoft 365 x64
With threads like these, no wonder ChatGPT is suggesting CubeNext();
So Wim made a very reasonable request since your question made little, if any sense.Wim Gielis wrote: ↑Fri Feb 14, 2025 5:16 pmCan you please write a proper question ?sairajsoma wrote: ↑Fri Feb 14, 2025 8:39 am We can write N: right instead of S : for string element 'comment'
And you responded with something completely irrelevant making even less sense than the 1st "question."
I don't think it's even worth directing you to the request for assistance guidelines. Some people can't be helped.
- PavoGa
- Excel Version: 2013 PAW
Man, I've missed checking the Forum on a regular basis.lotsaram wrote: ↑Mon Feb 17, 2025 10:49 amSo Wim made a very reasonable request since your question made little, if any sense.Wim Gielis wrote: ↑Fri Feb 14, 2025 5:16 pmCan you please write a proper question ?sairajsoma wrote: ↑Fri Feb 14, 2025 8:39 am We can write N: right instead of S : for string element 'comment'
Ty
Cleveland, TN
Cleveland, TN
