Connect to TM1 from Cognos Insight
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Post by ioscat »
Hello, forum.
I got a problem that I cannot find how to solve.
The planning server configuration settings could not be found. Initialize the planning server then press enter to try connectiong again.
I tried to put "localhost" to the string but with no success
Has anybody met this one?
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Re: Connect to TM1 from Cognos Insight
Post by Duncan P »
Have you tried pasting that URL into a browser? If so then it might redirect you to the configuration page where it will create the file it is looking for.
ioscat
Post by ioscat »
http://localhost:9510/pmpsvc opens ok...
IntegratedSecurityMode = 1
is BI necessary to Insight work?
kaazimraza
OLAP Product: TM1, SSAS, Power BI
Post by kaazimraza »
ioscat wrote:http://localhost:9510/pmpsvc opens ok...
No, BI is not necessary to make Cognos Insight work. on my local machine I am able to access my local TM1 server from Cognos Insight only if I launch it from TM1 applications page. If I launch Cognos Insight stand alone, and then try to connect it to the URL, it keeps on prompting me with invalid credentials message.
Hope this helps.
Kaz
ioscat
Post by ioscat »
I got connected to the TM1 server, thaks for advice. But when I try to put a cube view to the workspace I got disconnected. Import data did not succeed too. I can't even google this error. =(
Error connecting to the Cognos TM1 server: Cognos Insight will now close the connection to TM1
ioscat
Post by ioscat »
The issue was caused by incorrect MDX that somehow passed to work in Architect, TM1Web, Contributor. I corrected it and finaly got Insight display my cube view.
kaazimraza
ioscat wrote:The issue was caused by incorrect MDX that somehow passed to work in Architect, TM1Web, Contributor. I corrected it and finaly got Insight display my cube view.
Glad to know that it's resolved. MDX bit is pretty interesting, maybe that's because Cognos Insight was expecting an MDX statement different than Architect/Contributor/Web?
Kaz
margauxbrand
Version: 10.2.1
Post by margauxbrand »
Please help... I get the same error message... I can open my cubeview and move a few dimensions around, but then after a few minutes it starts to 'hang' and ultimately pops up with the "Error connecting to the Cognos TM1 server: Cognos insight will now close." message.
I am pretty new at TM1 administration, so could anyone please advise where I go to amend "incorrect MDX"? Assuming that my error message is caused by the same problem. Thanks!
