Dimension elements into Excel cell drop down
sathishh.mk
Version: 9.4 and 9.5
Excel Version: 2003 and 2007
Post by sathishh.mk »
We are trying to show the Dimension elements into excel cell drop down list of values.
Is any function that calls the dimension elements into excel.
Please help me on this.
Please Let me know if you need more details.
Regards.
Sathish
EvgenyT
Version: PAL 2.0.8
Re: Dimension elements into Excel cell drop down
Post by EvgenyT »
SUBNM() will give you an ability to navigate TM1 dimension.
DIMIX() will give you an ability to retrieve TM1 elements from a dimension based on the Index ( Probably want you need in this case)
They are explained in details in Worksheet Function Overview part of TM1 guide
Evgeny
sathishh.mk
Thanks for reply.
We tried with Subnm(),Dimix functions,but there are not working the way we are looking for.
Please find the attached screen shot for reference.
Sathish
Dimension in ExcelDropdown.jpg (40.6 KiB) Viewed 5939 times
sathishh.mk wrote: Thanks for reply.
Look in the manuals for the word "Picklists".
binhnguyenthy
OLAP Product: TM1 IBM
Post by binhnguyenthy »
hi
You can use SUBNM funtion, before You must connect server TM1.
=SUBNM("Retail:Product","All","1","VN")
http://pic.dhe.ibm.com/infocenter/ctm1/ ... D5_2_6_6_9
After you run it on TM1 application, you can see what you want
binhnguyenthy wrote:hi
I appreciate that as a new member here you're trying to help, but to ensure that we retain high quality answers you do need to read the question carefully and be sure that you're replying to what the question really is.
In this case the question was about creating a drop-down list in a cell in Excel, as the screenshot in the third post.
You've provided a link to a TurboIntegrator function which inserts new elements into a dimension, and a screenshot of what appears to be TM1 Web. The two don't seem to be highly connected to the question asked.
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
If you set the cells in TM1 to have a pick-list using the dimension the members of which you want to see then it will appear as a normal drop-down in Excel.
For information on how to set up a pick-list there is a section in the documentation here.
