We are trying to show the Dimension elements into excel cell drop down list of values.
Is any function that calls the dimension elements into excel.
Please help me on this.
Please Let me know if you need more details.
Regards.
Sathish
Dimension elements into Excel cell drop down
sathishh.mk
- Version: 9.4 and 9.5
EvgenyT
- Version: PAL 2.0.8
Re: Dimension elements into Excel cell drop down
SUBNM() will give you an ability to navigate TM1 dimension.
DIMIX() will give you an ability to retrieve TM1 elements from a dimension based on the Index ( Probably want you need in this case)
They are explained in details in Worksheet Function Overview part of TM1 guide
Evgeny
Evgeny
sathishh.mk
Thanks for reply.
We tried with Subnm(),Dimix functions,but there are not working the way we are looking for.
Please find the attached screen shot for reference.
Sathish
Thanks for reply.
Sathish
- Dimension in ExcelDropdown.jpg (40.6 KiB) Viewed 5943 times
Look in the manuals for the word "Picklists".sathishh.mk wrote: Thanks for reply.
binhnguyenthy
- OLAP Product: TM1 IBM
- Version: 10.2
hi
You can use SUBNM funtion, before You must connect server TM1.
=SUBNM("Retail:Product","All","1","VN")
http://pic.dhe.ibm.com/infocenter/ctm1/ ... D5_2_6_6_9
After you run it on TM1 application, you can see what you want
- h5.png (64.96 KiB) Viewed 5862 times
I appreciate that as a new member here you're trying to help, but to ensure that we retain high quality answers you do need to read the question carefully and be sure that you're replying to what the question really is.binhnguyenthy wrote:hi
In this case the question was about creating a drop-down list in a cell in Excel, as the screenshot in the third post.
You've provided a link to a TurboIntegrator function which inserts new elements into a dimension, and a screenshot of what appears to be TM1 Web. The two don't seem to be highly connected to the question asked.
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
If you set the cells in TM1 to have a pick-list using the dimension the members of which you want to see then it will appear as a normal drop-down in Excel.
For information on how to set up a pick-list there is a section in the documentation here.
