Dynamic Subset isn't working at Title
hisathishkumar
- OLAP Product: TM1 and BI
- Version: PA 2.0
- Excel Version: PA
my first post here and kind of a newbie to TM1 PA.
I have created a dynamic subset filtered attribute(YearNo attribute on Employee Dim, and attribute value is an element from other dimension (Year dimension). When i placed the Employee DIM as Row or column its working fine based on the Year Dim filter which is at TITLE. however its not working when i placed both the EMPLOYEE and YEAR dimensions at TITLE (context).
Dim1 - EmployeeOrguHR and YearNo is attr
Dim2 - Year and YearNo_txt is an attr
following is the MDX on EmployeeOrguHR dimension
{FILTER( {TM1SubsetBasis()}, [EmployeeOrguHR].[YearNo] = [Year].[YearNo_txt])}
Highly appreciate any suggestions.
- gtonkin
Re: Dynamic Subset isn't working at Title
First thing to do is correct the MDX - TM1SubsetBasis() is probably unknown in this context - typically added when recording MDX.
Replace that with the [dim].[member] or set you are starting from and try again.
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Hi, what interface are you using?
If it is tm1web, it will not work. such dynamic subsets work only when Year is in context and Employee is in rows/columns
"Both dims in filters" will work only in PAW (until you drag them out of the view to external selector widget)
hisathishkumar
- Version: PA 2.0
- Excel Version: PA
Thanks for the response @gtonkin
i have used the following MDX later on, but still the same issue.
{FILTER( {TM1SUBSETALL( [EmployeeOrguHR] )}, [EmployeeOrguHR].[YearNo] = [Year].[YearNo_txt])}
hisathishkumar
- Version: PA 2.0
- Excel Version: PA
Thank you for the response @Elessar, apologies for the late response.Elessar wrote: ↑Fri Jan 21, 2022 12:34 pm Hi, what interface are you using?
This is for PAW only, it is working fine when both YEAR and EmployeeOrguHR Dimensions in TITLE/filter. however, as you said, it is not working when i Drag EmployeeOrguHR dim out of the view and made them as a external filers(generic filters for multiple widgets on the same dashboard).
Is there any way to get that working? either by changing the MDX or changing something in PAW?
Thank you
- tempsnip.png (93.11 KiB) Viewed 31321 times
Last edited by hisathishkumar on Mon Jan 24, 2022 11:47 pm, edited 1 time in total.
hisathishkumar
- Version: PA 2.0
- Excel Version: PA
Thank you @Win Gielis, looks an amazing document. apologies for the late response.Wim Gielis wrote: ↑Fri Jan 21, 2022 12:28 pm Hello,
Please read this lengthy page on MDX:
https://www.wimgielis.com/tm1_mdxstatements_EN.htm
- Elessar
- Version: 2.0.9
No. Somebody has already asked this on IBM community forum: IBM said that when you drag filter to external widget, MDX becomes disconnected from view.hisathishkumar wrote: ↑Mon Jan 24, 2022 11:39 pm
hisathishkumar
- Version: PA 2.0
- Excel Version: PA
Thank you for the quick response.Elessar wrote: ↑Tue Jan 25, 2022 7:12 amNo. Somebody has already asked this on IBM community forum: IBM said that when you drag filter to external widget, MDX becomes disconnected from view.hisathishkumar wrote: ↑Mon Jan 24, 2022 11:39 pm
i came across the following article,they say it works when both are at Title, tried this logic, its throwing an error "Invalid MDX expression".
https://quebit.com/askquebit/IBM/how-to ... cube-view/
Mark RMBC
- Version: 10.1.1
- Excel Version: Excel 2010
As Ellessar has said twice already, what you are trying to do will NOT work if both dimensions are dragged outside the cube view.
I posted about this issue here, please read the whole thread:
https://community.ibm.com/community/use ... gestviewer
Hopefully IBM will resolve this at some point but feel free to add a comment saying you have the same problem, might help speed things along.
My workaround was to create some client attributes, have those as the selectors on the page and let the mdx reference those instead.
regards,
Mark
regards,
Mark
hisathishkumar
- Version: PA 2.0
- Excel Version: PA
Thanks Mark, will try your workaround suggestion .Mark RMBC wrote: ↑Tue Jan 25, 2022 10:37 am Hi,
regards,
Mark
