Dynamic Subset isn't working at Title
hisathishkumar
OLAP Product: TM1 and BI
Version: PA 2.0
Excel Version: PA
Post by hisathishkumar »
my first post here and kind of a newbie to TM1 PA.
I have created a dynamic subset filtered attribute(YearNo attribute on Employee Dim, and attribute value is an element from other dimension (Year dimension). When i placed the Employee DIM as Row or column its working fine based on the Year Dim filter which is at TITLE. however its not working when i placed both the EMPLOYEE and YEAR dimensions at TITLE (context).
Dim1 - EmployeeOrguHR and YearNo is attr
Dim2 - Year and YearNo_txt is an attr
following is the MDX on EmployeeOrguHR dimension
{FILTER( {TM1SubsetBasis()}, [EmployeeOrguHR].[YearNo] = [Year].[YearNo_txt])}
Highly appreciate any suggestions.
Re: Dynamic Subset isn't working at Title
First thing to do is correct the MDX - TM1SubsetBasis() is probably unknown in this context - typically added when recording MDX.
Replace that with the [dim].[member] or set you are starting from and try again.
BR, George.
Please read this lengthy page on MDX:
https://www.wimgielis.com/tm1_mdxstatements_EN.htm
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Hi, what interface are you using?
If it is tm1web, it will not work. such dynamic subsets work only when Year is in context and Employee is in rows/columns
"Both dims in filters" will work only in PAW (until you drag them out of the view to external selector widget)
hisathishkumar
Version: PA 2.0
Excel Version: PA
gtonkin wrote: Fri Jan 21, 2022 10:24 am First thing to do is correct the MDX - TM1SubsetBasis() is probably unknown in this context - typically added when recording MDX.
Thanks for the response @gtonkin
i have used the following MDX later on, but still the same issue.
{FILTER( {TM1SUBSETALL( [EmployeeOrguHR] )}, [EmployeeOrguHR].[YearNo] = [Year].[YearNo_txt])}
hisathishkumar
Version: PA 2.0
Excel Version: PA
Elessar wrote: Fri Jan 21, 2022 12:34 pm Hi, what interface are you using?
Thank you for the response @Elessar, apologies for the late response.
This is for PAW only, it is working fine when both YEAR and EmployeeOrguHR Dimensions in TITLE/filter. however, as you said, it is not working when i Drag EmployeeOrguHR dim out of the view and made them as a external filers(generic filters for multiple widgets on the same dashboard).
Is there any way to get that working? either by changing the MDX or changing something in PAW?
Thank you
Last edited by hisathishkumar on Mon Jan 24, 2022 11:47 pm, edited 1 time in total.
hisathishkumar
Version: PA 2.0
Excel Version: PA
Wim Gielis wrote: Fri Jan 21, 2022 12:28 pm Hello,
Thank you @Win Gielis, looks an amazing document. apologies for the late response.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
hisathishkumar wrote: Mon Jan 24, 2022 11:39 pm
No. Somebody has already asked this on IBM community forum: IBM said that when you drag filter to external widget, MDX becomes disconnected from view.
hisathishkumar
Version: PA 2.0
Excel Version: PA
Elessar wrote: Tue Jan 25, 2022 7:12 am
Thank you for the quick response.
i came across the following article,they say it works when both are at Title, tried this logic, its throwing an error "Invalid MDX expression".
https://quebit.com/askquebit/IBM/how-to ... cube-view/
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
As Ellessar has said twice already, what you are trying to do will NOT work if both dimensions are dragged outside the cube view.
I posted about this issue here, please read the whole thread:
https://community.ibm.com/community/use ... gestviewer
Hopefully IBM will resolve this at some point but feel free to add a comment saying you have the same problem, might help speed things along.
My workaround was to create some client attributes, have those as the selectors on the page and let the mdx reference those instead.
regards,
Mark
hisathishkumar
Version: PA 2.0
Excel Version: PA
Mark RMBC wrote: Tue Jan 25, 2022 10:37 am Hi,
regards,
Mark
Thanks Mark, will try your workaround suggestion .
