Mix Dynamic Subset with Static Ones
macsir
Version: PAL 2.0.9
Post by macsir »
Hi, All
I just noticed if I created one static subset based on the mixed dynamic subsets and static subsets. I can use the parent without any problem for the day and all children are there. But if the server restarts, that parent static subset will automatically exclude the dynamic child subsets, which means only static children are left. The dynamic children are simply not included in that parent.
Does anyone have same situation? I am on 10.2.2.
Re: Mix Dynamic Subset with Static Ones
macsir wrote:Hi, All
Honestly, I don't understand what you are telling here.
Can you provide step by step instructions to reproduce the problem, with a dummy dimension for example ?
If not, I bet you will not get a lot of valuable feedback.
Thanks.
macsir
Version: PAL 2.0.9
Post by macsir »
Ok, here is the example.
Default is dynamic subset and FY 2004 Budget is the static. I created a static parent Subset1 to include both. After server restarts, the Subset1 only has FY 2004 Budget left.
2015-10-23 08_36_43-Subset Editor_  Planning Sample-_plan_version-_FY 2004 Budget  [Public].png
2015-10-23 08_36_43-Subset Editor_ Planning Sample-_plan_version-_FY 2004 Budget [Public].png (12.27 KiB) Viewed 5002 times
2015-10-23 08_36_32-Subset Editor_  Planning Sample-_plan_version-_Default  [Public].png
2015-10-23 08_36_32-Subset Editor_ Planning Sample-_plan_version-_Default [Public].png (14.56 KiB) Viewed 5002 times
2015-10-23 08_36_13-Subset Editor_  Planning Sample-_plan_version-_Subset1  [Public].png
2015-10-23 08_36_13-Subset Editor_ Planning Sample-_plan_version-_Subset1 [Public].png (10.86 KiB) Viewed 5002 times
macsir
Version: PAL 2.0.9
Post by macsir »
after restarts
2015-10-23 08_40_16-Subset Editor_  Planning Sample-_plan_version-_Subset1  [Public].png
2015-10-23 08_40_16-Subset Editor_ Planning Sample-_plan_version-_Subset1 [Public].png (13.58 KiB) Viewed 5000 times
macsir
Version: PAL 2.0.9
Post by macsir »
I think the reason is just because the parent is static anyway.
I see what you mean. But I cannot reproduce it. After server restart, everything is the same as before.
I am on 10.2.2 FP4, if that matters.
macsir
Version: PAL 2.0.9
Post by macsir »
Thanks, Wim
We are not in the latest FP4 yet. And I will try it later and post it.
Okay, thanks for keeping us informed.
macsir
Version: PAL 2.0.9
Post by macsir »
Yes, Wim. The FP4 fixed this issue.
Thank you for confirmation macsir.
