Hi, I am new to TM1 and hope that someone help me with a problem.
Is it possible to remove 'total element' from a hierarchy dimension? All attempts at doing this fail - after executing the process, the 'create total element' box goes back to being ticked, so I assume that this is the case.
Thank you for your guidance in advance.
hierarchy dimension and total element
compilersaysyes
- Version: 10.2
- Excel Version: 15.0.4659.1001
Re: hierarchy dimension and total element
Can you be more specific? What is your Turbo Integrator code?
What "Advanced" tabs in the process do you use ?
The OP is using Performance Modeller wizard to create the dimension as opposed to TI; hence the "Create Total Element" tick box. I've just tested this on an example in 10.2.2 though and left the box unticked when I set up the process; ran it and the dim was created without a Total. I then closed it all down and went back in and it was still unticked as it was when I saved it.
What exact version are you using? Can you post a screenshot of your "Maps" tab from PM?
Oh thanks, I did not realize the Performance Modeler part.
Just another thought on this, I haven't used PM much for this sort of thing but when I previously did some testing I found that it didn't always seem to like it when i changed an existing process. Did you originally create it with the "create total element" box ticked and then open it up and untick then save? If so I would try recreating from scratch but without ticking the box from the offset.... and then if that resolves it, you can definitely call it a bug and log it with IBM.
compilersaysyes
- Version: 10.2
Hello, thank you for your comments. I have attached a screenshot of the maps page. The total has a caption. Could this be causing the issue?
(I am trying to remove total element from the Grades dimension. I can untick the box just fine, but after saving, the box reverts back to being ticked.)
Thank you again
Thank you again
- screenshot.png (320.66 KiB) Viewed 4596 times
