Picklist problem
Willi
Version: 9.5.2
Picklist problem
Post by Willi »
I have a question about Picklists in TM1 9.5.2 with Excel 2010. I defined a Lookup-Cube where I want to define all my Picklists because they are not used in an active form. They are used in the static area of the Sheet. The picklist works in Cubeviewer:
Screenshot Cubview
Screenshot Cubview
But if I reference the Cell i Excel with a DBRW the Dropdown does not appear:
What am I missing?
Thanks in advannce
Re: Picklist problem
If you slice that one-cell-view to Excel to get the correct DBRW, what happens?
Willi
Version: 9.5.2
Post by Willi »
It's not sliced. I inserted the DBRW manually in an existing Excel.
Oh, in the Moment I pressed SUBMIt I got the question. If I slice it down it works. A hidden Tab is created. But even if I create the Tab manually in my existing Excel and create the Datavalidation it does not work
Do you use an Active form instead of a slice?
Willi
Version: 9.5.2
Post by Willi »
Yes. The Excel-Sheet contains an active form but the Picklist is used in the static area above the active form
As I said, slice (not active form) the cell with the picklist from the Cubeviewer to a new file.
If that works correctly, copy/paste the DBRW formula and the cells it refers to, to your sheet, above the active form.
Willi
Version: 9.5.2
Post by Willi »
I tried that, it's not working
And DBR instead of DBRW?
Willi
Version: 9.5.2
Post by Willi »
No, no change
Willi
Version: 9.5.2
Post by Willi »
It semms to be a Problem with the Excel-Cell/Row7Column. I put the DBRW-Formula in another cell and that works. I test a bit more
Willi wrote:It semms to be a Problem with the Excel-Cell/Row7Column
What might this be??? A cell, a row, a column, ... ?
Willi
Version: 9.5.2
Post by Willi »
I've really no idea what was the issue. I put the DBRW-Formula in another Cell and it works. Beside a border the cell had no formatting.
You could have pasted a "good" empty cell over that "strange" cell and tried again.
Willi
Version: 9.5.2
Post by Willi »
Sorry for the late reply. I Cannot try this. The linr where I originaly tried to place the picklist is now deleted.
But really thx for the help!
