TM1 10.2 64b on Windows 8.1 64b
vensyd
OLAP Product: SSAS
Excel Version: Excel 2013
Post by vensyd »
Hello guys,
Am trying to install TM1 10.2 64b on Windows 8.1 64-Bit but its throw an error saying:
"This App can't run on your PC"
To find a version for your PC, check with the software publisher.
Does not TM1 10.2 support Windows 8.1?
Or is there any alternative way to install this?
Re: TM1 10.2 64b on Windows 8.1 64b
vensyd wrote: Am trying to install TM1 10.2 64b on Windows 8.1 64-Bit but its throw an error saying:
Hard to tell. The new and glossy IBM Software Product Compatibility Reports (SPCR) tool (which is used by their Supported Environment page) generates content that is at best cryptic and at worst unfathomable.
vensyd wrote:Or is there any alternative way to install this?
Considering that I do indeed have a 10.2 test environment running on a 64 bit Win 8.1 (cursed be its name) box, whether it's officially supported or not is less of an issue than the fact that it works.
Provided, of course, you install it under an Admin login, and run the install "As Administrator".
(Apropos the above comment... yeah, this is really helpful and informative, thanks for that Iboglix, it clarifies the issue enormously.)
vensyd
OLAP Product: SSAS
Post by vensyd »
Thanks Alan,
Tried to run setup as Administrator. Still throws below error:
Error
Error
Update: I re-copied the s/w to my laptop and tried to install as Administrator ... now it has started installing. Not sure what was wrong with my previous copy. :)
vensyd wrote:Update: I re-copied the s/w to my laptop and tried to install as Administrator ... now it has started installing. Not sure what was wrong with my previous copy. :)
Interesting; it's possible that given the monolithic size of the thing you didn't get all of the Taaaarrrgggzzz archive over and that as a result Windows 8.1, being Windows 8.1, mis-identified the installstream package as a 16 bit application.
In any case, all that matters is that you have it working.
macsir
Version: PAL 2.0.9
Post by macsir »
It should work as there is no significant change in the core from windows 7 to windows 8.1 apart from GUI.
vensyd
OLAP Product: SSAS
Post by vensyd »
It all installed well. But with Perspectives it throwing below error:
'Could not load an object because it is not available on this machine'
As per suggestion updated the secruity update, unregistered and registered back 'mscomctl.ocx' but still throwing same error.
using Excel 2010 32 Bit.
Any clues?
macsir wrote:It should work as there is no significant change in the core from windows 7 to windows 8.1 apart from GUI.
The number of older applications that I and others (per the MS forums) have had problems installing might beg to differ on the significance. As one poster said, "I didn't agree to give up my licence to {insert software here} when I went to Windows 8". Even newer software isn't exempt; you'll get an incompatibility warning when installing SQL Server 2008 (a whole 5 years and 1 version old) for instance, and the warning isn't bogus. Some functionality which works fine in Win 7 but which will hang the system in Win 8 can attest to that.
vensyd wrote:It all installed well. But with Perspectives it throwing below error:
Any clues?
Some, yes.
vensyd
OLAP Product: SSAS
Post by vensyd »
Thanks Alan,
I did gone through these and followed your tips in some posts.
Also followed your tip to delete all exd files and try ... but still the same error.
vensyd wrote:Thanks Alan,
Did you try this one from Moby91's post in this thread?
Someone here had the same problem just last week and that was the solution to it.
vensyd
OLAP Product: SSAS
Post by vensyd »
Yes tried with both links... no joy :-(
If you right click on your mscomctl.ocx and select properties what version does it show?
Mine is 6.01.9834 and works a treat. There are a couple of older versions (not significantly older by any means) that will cause that error to be thrown.
vensyd
OLAP Product: SSAS
Post by vensyd »
I got Mscomctl.ocx with version 6.1.98.33 in c:\Windows\SysWOW64.
vensyd wrote:I got Mscomctl.ocx with version 6.1.98.33 in c:\Windows\SysWOW64.
And you definitely unregistered it (and got a confirmation that the unregistering was successful) and re-registered it (and got a message that that was successful), yes?
vensyd
OLAP Product: SSAS
Post by vensyd »
Downloaded MSCOMCTL.OCX File Version: 6.01.9834 and un-registered and re-registered and Error is gone now.
Thanks guys for the help.
vensyd
OLAP Product: SSAS
Post by vensyd »
Script to un-register and de-register MSCOMCTL.OCX
reg delete hkcr\typelib\{831FDD16-0C5C-11D2-A9FC-0000F8754DA1}\2.0 /f
if exist %systemroot%\SysWOW64\cscript.exe goto 64
%systemroot%\system32\regsvr32 /u mscomctl.ocx
%systemroot%\system32\regsvr32 mscomctl.ocx
exit
:64
%systemroot%\sysWOW64\regsvr32 /u mscomctl.ocx
%systemroot%\sysWOW64\regsvr32 mscomctl.ocx
exit
May be helpful for soneone who faces with same issue.
macsir
Version: PAL 2.0.9
Post by macsir »
Glad it is working and thanks for sharing.
