Automatic rebuild of a worksheet
sander
OLAP Product: tm1
Post by sander »
Hello All,
I have a worksheet(active form) in tm1, which I use both in excel and in Tm1Web, the form looks like this;
As you can see in the TM1RPTROW function in cel B17 I refer to cell C11. I do this to get the right subset in this function.
This all works fine exept I have to rebuild the worksheet every time I change the value in cell c11 to recalc the TM11RPTROW function, recalc doesn'tdo here.
Is there any possibility to automaticly rebuild the sheet after a change in a selection, i don't want to use a macro because I also need this functionality in Tm1Web.
I've looked at the TM1REBUILDOPTION, but that's only a solution when the file is opened.
Can anyone help me out here? TIA!
O, for you interested, we are trying to make a workaround for acces table functionality of Cognos EP. Because websheets are now made available in Tm1 10 contributor, we think this is possible with the above solution.
Re: Automatic rebuild of a worksheet
sander wrote:Is there any possibility to automaticly rebuild the sheet after a change in a selection, i don't want to use a macro because I also need this functionality in Tm1Web.
Just use a TM1 action button that rebuilds the form as it's "action". It will work in both Excel and TM1Web.
sander
OLAP Product: tm1
Post by sander »
Tomok, I've seen this also, but this is not 'automatic', what I want is when I do the selection the sheet automicly rebuilds. What happens here is, I make a selection and then I have to click on the action button.
Thnx for your reply,
Sander
sander wrote:Tomok, I've seen this also, but this is not 'automatic',
It may not be automatic but it's the only option that will do what you want for TM1Web.
sander
OLAP Product: tm1
Post by sander »
OK, we will have to do it with this functionality. Thnx for your replies!
GreetZ, Sander
