Weightings not changing
Hey Guys/Ladies
I am trying to change some elements weightings from 1 to 0 but nothing happens. It still stays 1.
Stupid question I know but I do not have the energy to struggle this morning.
Any ideas?
Thanx!
Any ideas?
Thanx!
Re: Weightings not changing
How are you doing this; dimension editor, .xdi, TI...?par3 wrote:Hey Guys/Ladies
Any ideas?
Thanx!
You're definitely trying to change child elements, not an element which isn't a child? (I know that's obvious, but the DE does let you change the weighting of a parent via the element properties... except of course it always bounces back to 1 after you close the properties dialog, which sounds like what you're describing.)par3 wrote:Dimension editor.
Any chance you could post some screen shots showing what's happening? It's a bit difficult to diagnose with the information available.
are you trying to change the weight of an element that is not a child of a consolidation element? You can only change the weight of an element if its under a consolidation element.
That answer sounds... oddly familiar, somehow.macky29 wrote:are you trying to change the weight of an element that is not a child of a consolidation element? You can only change the weight of an element if its under a consolidation element.
Nothing wrong with some confirmation - AK.
Thanks for the enlightenment - NH.nhavis wrote:Nothing wrong with some confirmation - AK.
Of course "confirmation" usually involves making a reference to a previous answer.
The absence of such a reference usually means "didn't read the thread before replying".
Everyone's done it from time to time, but it's not a good habit to get into which is why a gentle tap on the shoulder is no bad thing.
adnantage
- Version: 10.2
I have added ALL_ABC kind of consolidations to roll up numeric elements to a consolidation in each dimension of a cube. All the elements in dimensions are added as children to a Consolidation and the weight for both elements and consolidations are 1 (by default).
For some reason the values are not rolled up to the consolidations and therefore cube shows no records but when I select the leaf level elements in dimensions then it does shows single record.
I have also tried to change consolidation weight to 0 but it doesn’t save it and pulls back 1.
Any idea why is it doing it?
Adnan
Adnan
Are the values for the n-level elements rule calculated? If so it sounds like they aren't fed. (Or a c-level rule that results in a zero overriding the standard consolidation.)adnantage wrote:I have added ALL_ABC kind of consolidations to roll up numeric elements to a consolidation in each dimension of a cube. All the elements in dimensions are added as children to a Consolidation and the weight for both elements and consolidations are 1 (by default).
Adnan
If that's not the case it could be beneficial for you to provide a snapshot of the dimension hierarchy (with the consolidation selected and the properties window on so we can see the weightings) and then also a snapshot of the cube in question showing where it doesn't consolidate as expected. A right-click on the cell that isn't consolidating and selecting "Trace Calcs" will give more of a view as to exactly what it thinks it is supposed to be doing.
