Contributor/Planner Layout
Jonsulli
Version: 9.5
Post by Jonsulli »
Hi There,
Users would like to get a contributor/Planner layout more user-friendly, but it seems really impossible to change the formating of the web view (like Border or cell color). Any idea ?
I know I could use report studio or business insight, however they need to use Contributor to fill their budget. SO report studio or business insght is not an option.
stephen waters
Version: 10_2_2
Excel Version: Excel 2010
Re: Contributor/Planner Layout
Post by stephen waters »
Jonsulli wrote:Hi There,
Contributor is a pretty basic interface(probably to avoid exciting former COgnos Planning users!). Why not use Web sheets? You will have all\most functionality of Excel formatting and can design a much nicer, more flexible, guided user experience. If you wish to use it with contributor work flow you will need to be on 10.1
Jonsulli
Version: 9.5
Post by Jonsulli »
Thanks Stephen I did not know
I tried, unfortunately, it seems it's not usable by Cognos express Planner 10.1 only with TM1...
mvaspal
OLAP Product: tm1
Version: 10 2 2 - 2.0.5
Post by mvaspal »
I would be surprised if websheets couldn't be used in CX 10.1
I would rather guess that you enabled this application also for Cognos Insight but websheets are not allowed to be used in Insight.
Jonsulli wrote:Thanks Stephen I did not know
You can definitely use websheets in CX 10.1 Planner applications!
What you can't do in either TM1 or CX is use Cognos Insight as a distributed or connected client for any application that uses websheets. Insight supports views only.
Jonsulli
Version: 9.5
Post by Jonsulli »
You were absolutely right mvaspal and Lostaram !!!
It works perfectly now !!!
:D
Thanks a lot
/bow
