Hey ,
Is it possible to downgrade from 10.1.1 to 9.5.2 ??
downgrade tm1 from 10.1.1 to 9.5.2
- OLAP Product: tm1
- Version: 10.1.1
- Excel Version: 10
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: downgrade tm1 from 10.1.1 to 9.5.2
Yes, just uninstall 10.1.1 and install 9.5.2 (database structure is compatible both ways). However, I'm a bit curious why you would want to downgrade.sharath0525 wrote:Hey ,
Michel
- OLAP Product: tm1
- Version: 10.1.1
- Excel Version: 10
Hey micheal ,
Thanks for your reply .
The scenario is like one server got installed with 9.5.2 and another with 10.1.1 .
Currently we are using 10.1.1 but entire project is moving to another server which is installed with 9.5.2.
so I just wanted to know whether data in 10.1.1 cubes can be moved to 9.5.2 .
Also what would be the cases that can not be supported in 9.5.2
- Steve Vincent
- Version: 10.2.2 FP1
why not just update the server to 10.1.1? IBM will pull support to 9.5.2 eventually, keeping with 10.1.1 would mean you'd have longer on a single version. I'd only ever contemplate downgrading if a later version has critical issues stopping models from working.
- OLAP Product: tm1
- Version: 10.1.1
- Excel Version: 10
Hi steve
We are in process of migrating to 10.1.1 in the other server as well . But due to some other circumstances the upgrading is getting delayed . So we have to downgrade our project from 10.1.1 to 9.5.2 .
