downgrade tm1 from 10.1.1 to 9.5.2
sharath0525
OLAP Product: tm1
Version: 10.1.1
Excel Version: 10
Post by sharath0525 »
Hey ,
Is it possible to downgrade from 10.1.1 to 9.5.2 ??
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: downgrade tm1 from 10.1.1 to 9.5.2
Post by Michel Zijlema »
sharath0525 wrote:Hey ,
Yes, just uninstall 10.1.1 and install 9.5.2 (database structure is compatible both ways). However, I'm a bit curious why you would want to downgrade.
Michel
sharath0525
OLAP Product: tm1
Version: 10.1.1
Excel Version: 10
Hey micheal ,
Thanks for your reply .
The scenario is like one server got installed with 9.5.2 and another with 10.1.1 .
Currently we are using 10.1.1 but entire project is moving to another server which is installed with 9.5.2.
so I just wanted to know whether data in 10.1.1 cubes can be moved to 9.5.2 .
Also what would be the cases that can not be supported in 9.5.2
Steve Vincent
Version: 10.2.2 FP1
Post by Steve Vincent »
why not just update the server to 10.1.1? IBM will pull support to 9.5.2 eventually, keeping with 10.1.1 would mean you'd have longer on a single version. I'd only ever contemplate downgrading if a later version has critical issues stopping models from working.
sharath0525
OLAP Product: tm1
Version: 10.1.1
Excel Version: 10
Hi steve
We are in process of migrating to 10.1.1 in the other server as well . But due to some other circumstances the upgrading is getting delayed . So we have to downgrade our project from 10.1.1 to 9.5.2 .
