I would like to update the }CellSecurity_XCube by chore.
Unfortunately, the process is failing every time because security reason.
Could I set that the chore runs 'under' my account? or How could I fix this problem?
Thx,
Matya
Control cube update by chore
Re: Control cube update by chore
Right click on the process and tell me what your choices are...........
- qml
- Excel Version: 2007 - 2016
Matya, tomok has pointed you in the right direction. I will just add two things.
a) Each process always runs with rights equivalent to being executed by a member of DataAdmin security group, regardless of who/what actually kicks it off. That is unless a specific option is checked in the context menu (yes, the one tomok is hinting at) - in that case the process will run with both DataAdmin and SecurityAdmin rights (so effectively full Admin rights). This has been the case since a good few versions ago.
b) This topic has been covered tens of times on the forum, have you tried the fantastic Search function?
Kamil Arendt
http://publib.boulder.ibm.com/infocente ... tyDat.htmlMatya wrote:I'm sure I'm a looser, but I don't know what you mean...
This option has been required since version 9.4tomok wrote:Right click on the process and tell me what your choices are...........
Matya
Ok, I was a looser...
I forgot this option, it is friday...
Sorry for asking.
Sorry for asking.
