Change chore when process it contains changes?
dkirby10b
Version: 10.1.1
Post by dkirby10b »
I have an odd occurrence where a chore I created does not appear to be running the latest version of the process it contains.
Is this documented somewhere or has anyone come across this before?
Thanks in advance.
Version: PA 2.0.7
Re: Change chore when process it contains changes?
Post by jim wood »
I think I've heard of this before. I guess it depends on what version you are running?
dkirby10b
Version: 10.1.1
Post by dkirby10b »
We are running TM1/Cognos version 10.1.1 (on Windows 2008 R2 64-bit)
Version: PA 2.0.7
Post by jim wood »
I avoid chores if I can, but a while ago I think I remember somebody saying that chores included the code of their processes, in the same way that cubes include the rules just in case you delete the rux file. If you go in to the chore and and remove / add the process you'll be ok. Also is the chore currently active?
dkirby10b
Version: 10.1.1
Post by dkirby10b »
When I deleted and added the process back to the chore it worked fine. It just wasn't the behavior I was expecting.
Thanks for your responses.
Version: PA 2.0.7
Post by jim wood »
You're more than welcome. Did you do a search on the forum for this issue? I'm sure somebody posted about this at some point. Somebody else may chip in who remembers more details than me.....
