I have an odd occurrence where a chore I created does not appear to be running the latest version of the process it contains.
Is this documented somewhere or has anyone come across this before?
Thanks in advance.
Change chore when process it contains changes?
- jim wood
- Version: PA 2.0.7
Re: Change chore when process it contains changes?
I think I've heard of this before. I guess it depends on what version you are running?
dkirby10b
- Version: 10.1.1
We are running TM1/Cognos version 10.1.1 (on Windows 2008 R2 64-bit)
- jim wood
- Version: PA 2.0.7
I avoid chores if I can, but a while ago I think I remember somebody saying that chores included the code of their processes, in the same way that cubes include the rules just in case you delete the rux file. If you go in to the chore and and remove / add the process you'll be ok. Also is the chore currently active?
dkirby10b
- Version: 10.1.1
When I deleted and added the process back to the chore it worked fine. It just wasn't the behavior I was expecting.
Thanks for your responses.
- jim wood
- Version: PA 2.0.7
You're more than welcome. Did you do a search on the forum for this issue? I'm sure somebody posted about this at some point. Somebody else may chip in who remembers more details than me.....
