When I reference using the Format " & F16 & " it's not working? What is the correct format?
Reference Parameter to MDX Query from a Excel Cell
EvgenyT
- Version: PAL 2.0.8
Re: Reference Parameter to MDX Query from a Excel Cell
"&I10&" is correct format, yeah.
Please post your mdx ...
ET
ET
Abinaya
- Version: 9.5.2
- Excel Version: 2003
{FILTER( {TM1SUBSETALL( [Customer] )},[Customer] .Group=" &F16&")}
When I hard code the the Group it works.
EvgenyT
Ah ok. you gota use ' " & F16 &" ' ... Single, double, ampersand...Abinaya wrote:{FILTER( {TM1SUBSETALL( [Customer] )},[Customer] .Group=" &F16&")}
Because, I bet you when you look at your MDX string:
Abinaya wrote:{FILTER( {TM1SUBSETALL( [Customer] )},[Customer] .Group=" &F16&")} doesnt have ' ' around the value and MDX engine requires value to be in ' ' when you are filtering by attribute for example hence need for ' " & & " ' syntax
ET
Abinaya
- Version: 9.5.2
Sorry Still not working. Very strangely when I tried Text(F16,"") in the cell it worked.
EvgenyT
So you tried {FILTER( {TM1SUBSETALL( [Customer] )},[Customer].[Group]= '"&F16&"')} ?Abinaya wrote:Sorry Still not working. Very strangely when I tried Text(F16,"") in the cell it worked.
see simple example below
- Untitled.png (12.87 KiB) Viewed 9354 times
Abinaya
- Version: 9.5.2
Worked. Sorry for the confusion.
EvgenyT
All good.
' " & Cell Reference &" ' is a trick to use
ET
ET
