Reference Parameter to MDX Query from a Excel Cell
Abinaya
Version: 9.5.2
Post by Abinaya »
When I reference using the Format " & F16 & " it's not working? What is the correct format?
EvgenyT
Version: PAL 2.0.8
Re: Reference Parameter to MDX Query from a Excel Cell
Post by EvgenyT »
"&I10&" is correct format, yeah.
Please post your mdx ...
ET
Abinaya
Version: 9.5.2
Post by Abinaya »
{FILTER( {TM1SUBSETALL( [Customer] )},[Customer] .Group=" &F16&")}
When I hard code the the Group it works.
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
Abinaya wrote:{FILTER( {TM1SUBSETALL( [Customer] )},[Customer] .Group=" &F16&")}
Ah ok. you gota use ' " & F16 &" ' ... Single, double, ampersand...
Because, I bet you when you look at your MDX string:
Abinaya wrote:{FILTER( {TM1SUBSETALL( [Customer] )},[Customer] .Group=" &F16&")} doesnt have ' ' around the value and MDX engine requires value to be in ' ' when you are filtering by attribute for example hence need for ' " & & " ' syntax
ET
Abinaya
Version: 9.5.2
Post by Abinaya »
Sorry Still not working. Very strangely when I tried Text(F16,"") in the cell it worked.
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
Abinaya wrote:Sorry Still not working. Very strangely when I tried Text(F16,"") in the cell it worked.
So you tried {FILTER( {TM1SUBSETALL( [Customer] )},[Customer].[Group]= '"&F16&"')} ?
see simple example below
Abinaya
Version: 9.5.2
Post by Abinaya »
Worked. Sorry for the confusion.
Abinaya
Version: 9.5.2
Post by Abinaya »
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
All good.
' " & Cell Reference &" ' is a trick to use ;)
ET
