TM1 Cognos Express and Powerpoint
Rwilliams
Version: Cognos Express
Post by Rwilliams »
I am trying find out if Cognos Express version 9.5 is compatible with powerpoint?
I wanted to create reports from TM1 that I could link directly in powerpoint so would refresh when updated to save copying and pasting in - is this possible?
Re: TM1 Cognos Express and Powerpoint
Cognos Exporess is neither compatible or incompatible with Powerpoint. Microsoft Excel sheets, however, can be linked into Powerpoint. Since Xcelerator (part of CE) is an add-in to Excel, that's your path.
stephen waters
Version: 10_2_2
Excel Version: Excel 2010
Post by stephen waters »
tomok wrote: Since Xcelerator (part of CE) is an add-in to Excel, that's your path.
I seem to remember that Executive Viewer (ie Advisor in Cognos Express) had good integration with Powerpoint. May be worth looking at that as well.
Version: PA 2.0.7
Post by jim wood »
Tomok can't any of the report writer reports be linked in to Powerpoint? or does that need Cognos for MS office? If it does I'm guessing it doesn't hook in to Express?
Version: PA 2.0.7
Post by jim wood »
Good point Mr Waters. If nothing else you could try embedding html code.
The OP specifically said "TM1 reports", that's why I didn't mention the other component possibilties. My interpretation of that means cube views and/or TM1Web sheets.
