Hello experts,
I am new in TM1, when I installed TM1 10.1, the UI language of architect tool is in Chinese, I want it to show in English. But I can't find any option to change it? Do you have any idea about it ?
Any suggestions are appreciated.
How to change the user interface language of Architect?
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
Re: How to change the user interface language of Architect?
This is a suggestion (not an answer) and I don't have time to check it myself but there is a language setting in the TM1P.INI file, may be worth playing around with that.crazysand wrote: the UI language of architect tool is in Chinese, I want it to show in English. But I can't find any option to change it?
I don't know whether the language setting can vary between clients for the same server but maybe someone else has practical experience.
Please use Google on:
tm1p.ini parameters
and you will find the Language parameter.
Make sure you close all client applications, then change the INI file and start Architect again.
tm1p.ini parameters
Thank you all.
It works.
Find tm1p.ini in below path.
%ALLUSERSPROFILES%\Application Data\Applix\TM1\Tm1p.ini
add new parameters:
Language = eng
for other language:
ENG - English
FRA - French
DEU - German
JPN - Japanese
SCH - Simplified Chinese
ITA - Italian
ESP - Spanish
It works.
add new parameters:
Language = eng
for other language:
ENG - English
FRA - French
DEU - German
JPN - Japanese
ITA - Italian
ESP - Spanish
