Hello experts,
I am new in TM1, when I installed TM1 10.1, the UI language of architect tool is in Chinese, I want it to show in English. But I can't find any option to change it? Do you have any idea about it ?
Any suggestions are appreciated.
How to change the user interface language of Architect?
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
Re: How to change the user interface language of Architect?
This is a suggestion (not an answer) and I don't have time to check it myself but there is a language setting in the TM1P.INI file, may be worth playing around with that.crazysand wrote: the UI language of architect tool is in Chinese, I want it to show in English. But I can't find any option to change it?
I don't know whether the language setting can vary between clients for the same server but maybe someone else has practical experience.
Please use Google on:
tm1p.ini parameters
and you will find the Language parameter.
Make sure you close all client applications, then change the INI file and start Architect again.
tm1p.ini parameters
crazysand
- Version: 10.1
Thank you all.
It works.
Find tm1p.ini in below path.
%ALLUSERSPROFILES%\Application Data\Applix\TM1\Tm1p.ini
add new parameters:
Language = eng
for other language:
ENG - English
FRA - French
DEU - German
JPN - Japanese
SCH - Simplified Chinese
ITA - Italian
ESP - Spanish
It works.
add new parameters:
Language = eng
for other language:
ENG - English
FRA - French
DEU - German
JPN - Japanese
ITA - Italian
ESP - Spanish
