Can't commit data
- Version: 9.5.2
Can't commit data
We have recently upgraded from TM1 9.5.2 to 10.1.1 and I am trying to put some dummy data in to the cube,when i insert values in the cell against different combination on different department id and click the recalculate the values turns to zero ,when i check at aggregated level it is zero too.There must be something i am doing wrong here or it could be due to upgrade.Thanks a lot.
Re: Can't commit data
Please read the request for assistance guidelines and then try and rephrase your question. You should state what you have already done to investigate the issue.TM1ethusiast wrote:We have recently upgraded from TM1 9.5.2 to 10.1.1 and I am trying to put some dummy data in to the cube,when i insert values in the cell against different combination on different department id and click the recalculate the values turns to zero ,when i check at aggregated level it is zero too.
Also, would you be so kind as to state if you are an end user of TM1 - that means you are working for a company who has bought the tool. Or, are you a consultant/ contractor working for a company in a development and/or support capacity?
In my opinion you are doing something wrong. As stand-alone functionality, entering data in the cube is extremely basic functionality which is extremely unlikely to be affected by an upgrade.TM1ethusiast wrote:There must be something i am doing wrong here or it could be due to upgrade.Thanks a lot.
Robin Mackenzie
