10.1 Local Server
ladon
Version: 9.5
10.1 Local Server
Post by ladon »
I have just installed Tm1 10.1 Client and I'm unable to load the local server. When I click 'Start Local Server' nothing happens. Do I need to install Cognos TM1 Admin Server as well?
thanks in advance
macsir
Version: PAL 2.0.9
Re: 10.1 Local Server
Post by macsir »
I think you don't need to. Does the log file tell you anything?
ladon
Version: 9.5
Post by ladon »
you mean the install logs? nothing at all.
ladon
Version: 9.5
Post by ladon »
actually there is one warning :
Executing command "C:\Windows\Microsoft.NET\Framework\v2.0.50727\regasm.exe /codebase "C:\Program Files (x86)\ibm\cognos\tm1\bin\TM1RuleEditor.dll"" successstatus = 0 windowstyle = HIDDEN waitforexit = YES...
Successfully executed system command: "C:\Windows\Microsoft.NET\Framework\v2.0.50727\regasm.exe /codebase "C:\Program Files (x86)\ibm\cognos\tm1\bin\TM1RuleEditor.dll""
Warning: Application has returned exit code 100, Expecting return code 0.
Dont think that will affect local server though.
Steven Marshall
Version: TM1 10.1.1
Excel Version: 2003-2010
Post by Steven Marshall »
Hi Ladon,
You beat me to this, I have just encountered the exact same problem while testing 10.1.
I've tried in both perspectives and architect, server and client side but have had no luck - where did you find the warning, I couldn't find any logs or messages to indicate a problem.
I did however come across an outstanding PMR relating to a similiar issue with Cognos Express (PM39401)
" In Cognos Express 9.5.0, it is not possible to start a local
server from TM1 Architect component. Despite having a valid
Data Directory specified and having all the necessary files
present, the service just does not start. Starting it as an
application poses no problems. In a standalone TM1 environment,
there is no problem starting it as a local server. "
Steven
moby91
Version: 9.5.1
Excel Version: 2003 2007
Post by moby91 »
Steven Marshall wrote:I did however come across an outstanding PMR relating to a similiar issue with Cognos Express (PM39401)
Cognos Express 9.5 Perspectives does not support the Local Server, see the IBM Technote 1579420:
http://www-01.ibm.com/support/docview.w ... wg21579420
Cognos Express Xcelerator and Local Server support
or the open documentation defect logged as APAR PM57534:
https://www-304.ibm.com/support/entdocv ... wg1PM57534
PM57534: DOCUMENTATION DEFECT RE: LOCAL SERVER SUPPORT IN COGNOS EXPRESS 9.5
Harvey
Version: TM1 8.3 onwards
Excel Version: 2003 onwards
Post by Harvey »
Yes, I think I read also that this is not supported in CX. No idea why that's the case.
I have available a free tool that allows you to start up as many local servers as you like with a few clicks.
Here's a link.
If you want to run TM1 as a service in Windows 7/Vista, it's worth reading my blog post regarding this, too.
ladon
Version: 9.5
Post by ladon »
Steven Marshall wrote: I've tried in both perspectives and architect, server and client side but have had no luck - where did you find the warning, I couldn't find any logs or messages to indicate a problem.
It's in the C:\Program Files (x86)\IBM\cognos\tm1\instlog folder after installation.
