Format lost after export to excel !
Posted: Thu Jul 19, 2012 12:15 am
by phamtinkt88
I'm stucking with issue as the image below.
- Capture.JPG (142.56 KiB) Viewed 4022 times
Is there anyway to keep that format ?
Thanks all,
Tin Pham
Re: Format lost after export to excel !
Posted: Thu Jul 19, 2012 8:18 pm
by Martin Ryan
Is this a slice or an active form? A slice will usually automatically do this for you. And with an active form you can control the formatting using the hidden rows at the top of the sheet.
Alternatively you could put an ellev in a hidden column to determine whether the element is consolidated or not, and then apply conditional formatting based on that ellev result.
Martin
Posted: Tue Aug 21, 2012 3:03 am
by phamtinkt88
Martin Ryan wrote:Is this a slice or an active form? A slice will usually automatically do this for you. And with an active form you can control the formatting using the hidden rows at the top of the sheet.
Martin
Thanks Ryan, i did it as you said !
Posted: Tue Aug 21, 2012 8:22 am
by stephen waters
phamtinkt88 wrote:Martin Ryan wrote:Is this a slice or an active form? ....
Martin
Tin, he is too polite to say so but his first name is Martin!
