Format lost after export to excel !
phamtinkt88
OLAP Product: SAP BW,TM1
Version: 9.5.2-10.1.0
Excel Version: 2007-2010
Post by phamtinkt88 »
I'm stucking with issue as the image below.
Is there anyway to keep that format ?
Thanks all,
Tin Pham
Martin Ryan
Re: Format lost after export to excel !
Post by Martin Ryan »
Is this a slice or an active form? A slice will usually automatically do this for you. And with an active form you can control the formatting using the hidden rows at the top of the sheet.
Alternatively you could put an ellev in a hidden column to determine whether the element is consolidated or not, and then apply conditional formatting based on that ellev result.
phamtinkt88
Martin Ryan wrote:Is this a slice or an active form? A slice will usually automatically do this for you. And with an active form you can control the formatting using the hidden rows at the top of the sheet.
Thanks Ryan, i did it as you said !
stephen waters
Version: 10_2_2
Excel Version: Excel 2010
Post by stephen waters »
phamtinkt88 wrote:
Martin Ryan wrote:Is this a slice or an active form? ....
Tin, he is too polite to say so but his first name is Martin!
