CosolidateChildren error
Posted: Tue Jul 10, 2012 8:21 am
by Mems
Hey All,
I am using tm1 v9.5.2 FP2, but have replicated the issue on tm1 v9.5.1 ans Express v9.5.
The rule I am using is
['Weighted Formula Calc Inners'] =
IF(ELLEV('Item',!Item)<>0,
ConsolidateChildren('Item'),
['Inner Case Cost']*['Inner Case']);
The problem being, the cube runs at about 1GB and when I open cube viewer and specifically ['Weighted Formula Calc Inners'] the server (24GB) runs out of memory.
I have also tried writing it in different ways...
IF(ELLEV('Item',!Item)=0,
['Inner Case Cost']*['Inner Case'],
ConsolidateChildren('Item');
['Weighted Formula Calc Inners' ] =N:['Inner Case Cost']*['Inner Cases'];
['Weighted Formula Calc']=C:
Thinking that it might have something to do with a circular ref of sort.
Any ideas?
Admin note: moved from the bugs forum as it's not yet a proved bug.
Re: CosolidateChildren error
Posted: Tue Jul 10, 2012 9:15 am
by David Usherwood
Are you using feeders? You need to, then you can drop ConsolidateChildren. CC has its uses but can be very memory hungry.
Posted: Tue Jul 10, 2012 9:32 am
by Mems
David,
I broke it down to just one cube to fix the error.
The one extra rule.
['Inner Case Cost' ]=['Activity Cost']\['Inner Case']
Feeders;
['Inner Case' ]=>['Inner Case Cost' ] ;
['Inner Case' ] => ['Weighted Formula Calc Inners' ];
['Inner Case' ]=> ['Weighted Inner Case Cost' ];
The cube has 6 dimensions. Really small cube. Without the CC if I expand all elements the cube runs at 1GB. With CC server crashes.
Posted: Tue Jul 10, 2012 10:03 am
by Duncan P
So do you have a satisfactory solution not using ConsolidateChildren? I couldn't quite make out from your post if your problem was resolved.
Posted: Tue Jul 10, 2012 10:40 am
by David Usherwood
If you are doing weighted averages you need to roll them up:
['Weighted Formula Calc Inners'] = n:
Posted: Tue Jul 10, 2012 1:31 pm
by Mems
Hey,
Nope I believe I have to use ConsolidateChildren
https://docs.google.com/a/venncubed.co. ... li=1#gid=0
Please see URL
I want to get the 2.39.
My calcs are as follow
Skipcheck;
['Case Cost' ]=['Total Activity Cost']\['Cases']
['Weighted Formula Calc'] =
['Case Cost']*['Cases']);
Feeders;
['Cases' ]=>['Case Cost' ] ;
['Cases' ] => ['Weighted Formula Calc' ];
['Cases' ]=> ['Weighted Case Cost' ];
Posted: Tue Jul 10, 2012 1:48 pm
by Mems
Apologies,
Posted: Thu Jul 12, 2012 7:31 am
by Mems
Any feedback, regarding alternative ways except consolidatechildren to calculate?
Posted: Thu Jul 12, 2012 7:54 am
by declanr
Mems wrote:Hey,
Please see URL
Skipcheck;
Feeders;
Having had a look at your excel example (if I followed it correctly) I think you could solve your problem by simply using an =N: as below:
Skipcheck;
['Weighted Formula Calc'] =N:
['Case Cost']*['Cases'];
['Weighted Case Cost']=
['Weighted Formula Calc'] \ ['Cases'];
Feeders;
Or have I missed something really obvious, because the above code would be the equivalent of changing cell E2 in your example to be SUM(E3:E10) which would sebsequently change F2 to equal 2.39...
Posted: Thu Jul 12, 2012 9:34 am
by Mems
Hahahaha, ok I should get a new job :) thanks! My apologies for wasting time.
