CosolidateChildren error
Mems
Version: v10.2.2
Post by Mems »
Hey All,
I am using tm1 v9.5.2 FP2, but have replicated the issue on tm1 v9.5.1 ans Express v9.5.
The rule I am using is
['Weighted Formula Calc Inners'] =
IF(ELLEV('Item',!Item)<>0,
ConsolidateChildren('Item'),
['Inner Case Cost']*['Inner Case']);
The problem being, the cube runs at about 1GB and when I open cube viewer and specifically ['Weighted Formula Calc Inners'] the server (24GB) runs out of memory.
I have also tried writing it in different ways...
IF(ELLEV('Item',!Item)=0,
['Inner Case Cost']*['Inner Case'],
ConsolidateChildren('Item');
['Weighted Formula Calc Inners' ] =N:['Inner Case Cost']*['Inner Cases'];
['Weighted Formula Calc']=C:
Thinking that it might have something to do with a circular ref of sort.
Any ideas?
Admin note: moved from the bugs forum as it's not yet a proved bug.
MEMS
Re: CosolidateChildren error
Post by David Usherwood »
Are you using feeders? You need to, then you can drop ConsolidateChildren. CC has its uses but can be very memory hungry.
Mems
Version: v10.2.2
Post by Mems »
David,
I broke it down to just one cube to fix the error.
The one extra rule.
['Inner Case Cost' ]=['Activity Cost']\['Inner Case']
Feeders;
['Inner Case' ]=>['Inner Case Cost' ] ;
['Inner Case' ] => ['Weighted Formula Calc Inners' ];
['Inner Case' ]=> ['Weighted Inner Case Cost' ];
The cube has 6 dimensions. Really small cube. Without the CC if I expand all elements the cube runs at 1GB. With CC server crashes.
MEMS
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
So do you have a satisfactory solution not using ConsolidateChildren? I couldn't quite make out from your post if your problem was resolved.
If you are doing weighted averages you need to roll them up:
['Weighted Formula Calc Inners'] = n:
Mems
Version: v10.2.2
Post by Mems »
Hey,
Nope I believe I have to use ConsolidateChildren
https://docs.google.com/a/venncubed.co. ... li=1#gid=0
Please see URL
I want to get the 2.39.
My calcs are as follow
Skipcheck;
['Case Cost' ]=['Total Activity Cost']\['Cases']
['Weighted Formula Calc'] =
['Case Cost']*['Cases']);
Feeders;
['Cases' ]=>['Case Cost' ] ;
['Cases' ] => ['Weighted Formula Calc' ];
['Cases' ]=> ['Weighted Case Cost' ];
MEMS
Mems
Version: v10.2.2
Post by Mems »
Apologies,
ConsolidateChildren.xlsx
(10.05 KiB) Downloaded 488 times
MEMS
Mems
Version: v10.2.2
Post by Mems »
Any feedback, regarding alternative ways except consolidatechildren to calculate?
MEMS
Mems wrote:Hey,
Please see URL
Skipcheck;
Feeders;
Having had a look at your excel example (if I followed it correctly) I think you could solve your problem by simply using an =N: as below:
Skipcheck;
['Weighted Formula Calc'] =N:
['Case Cost']*['Cases'];
['Weighted Case Cost']=
['Weighted Formula Calc'] \ ['Cases'];
Feeders;
Or have I missed something really obvious, because the above code would be the equivalent of changing cell E2 in your example to be SUM(E3:E10) which would sebsequently change F2 to equal 2.39...
Mems
Version: v10.2.2
Post by Mems »
Hahahaha, ok I should get a new job :) thanks! My apologies for wasting time.
MEMS
