Add Cell level comments to TM1 10.1 Application
dhims
Version: 951 952 101 10101
Excel Version: 2003 2007 2010
Post by dhims »
Hey, anyone tried adding comment at cell level in TM1 10.1 Application. As i am trying to do so, i could see the button "Add Comments" is grayed out. Any idea about this issue.
I have created an application with application type 'Central'. Pls find the screenshot attached.
Screenshot.docx
Add Comment Greyed out
(105.08 KiB) Downloaded 605 times
rfielden
Version: 9.5.2
Re: Add Cell level comments to TM1 10.1 Application
Post by rfielden »
Does this application have approval hierarchy?
http://publib.boulder.ibm.com/infocente ... ntary.html
"See the IBM Cognos TM1 Performance Modeler Guide for more details about configuring comments in the model."
dhims
Post by dhims »
rfielden wrote:Does this application have approval hierarchy?
It doesnt have approval herirarchy. Actually, it should not matter as i am concern about cell level comments. If you refer the same link, it says "You can enter comments for a specific cell in either Cognos® TM1® Application Web or in Cognos Insight. These cell comments may be applied from within the client to any application type, whether it has an approval hierarchy or not."
foogy
Version: 10.2.2 FP6
Post by foogy »
Quite an old post but may be someone has an idea:
we use an approval hierarchy application in TM1 Applications and would like to prevent the usage of the "Add Comments" function on cell level. I did not find any hint in neither the TM1 documentation nor in Performance Modeler settings.
So for now I gave up and assume there is no option to switch this function off - correct?
