contributor 9.5_error.
viswaraju
OLAP Product: IBM COGNOS TM1
Version: 9.5
Post by viswaraju »
When I am trying to open a design application in a contributor, i have got an error window like,
C:\Document and settings\username\application data\cognos RCP\Logs\Provagent 8.4\Provagent_8.4_2012_05_08_12_53_23.log.
I am unable to design an application in contributor.
thanks and regards
2003 server
excel 2007
TM1 9.5.2
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: contributor 9.5_error.
Post by rkaif »
Try using TomCat for the Contributor
Also make sure you have applied the latest Fix patches
Cheers!
Rizwan Kaif
slique-cya
OLAP Product: TM1, Planning Analytics
Version: v9.5.2 v10.1, v2.0.6
Excel Version: v2003-2016
Post by slique-cya »
I have the same problem. I am using TomCat 6 as the webserver.
moby91
Version: 9.5.1
Excel Version: 2003 2007
Post by moby91 »
There are two different Contributor clients: The TM1 Contributor client and the Enterprise Planning (EP) Contributor client.
The TM1 Contributor client is using the TM1 Contributor Rich Client (RCP) framework.
The EP Contributor client is using the EP Contributor Rich Client (RCP) framework.
When you install both Contributor clients on the same computer, you must install the TM1 Contributor RCP framework before you install the EP Contributor RCP framework, see the IBM Technote 1454803 ->
http://www-304.ibm.com/support/docview. ... wg21454803
Unable to install TM1 Rich Client on computer which already has Planning 8.4 FP2 Rich Client
