When I am trying to open a design application in a contributor, i have got an error window like,
C:\Document and settings\username\application data\cognos RCP\Logs\Provagent 8.4\Provagent_8.4_2012_05_08_12_53_23.log.
I am unable to design an application in contributor.
thanks and regards
2003 server
excel 2007
TM1 9.5.2
contributor 9.5_error.
- rkaif
- Version: 9.1 or later
Re: contributor 9.5_error.
Try using TomCat for the Contributor
Also make sure you have applied the latest Fix patches
Cheers!
Rizwan Kaif
Rizwan Kaif
- OLAP Product: TM1, Planning Analytics
- Version: v9.5.2 v10.1, v2.0.6
- Excel Version: v2003-2016
I have the same problem. I am using TomCat 6 as the webserver.
- Version: 9.5.1
- Excel Version: 2003 2007
There are two different Contributor clients: The TM1 Contributor client and the Enterprise Planning (EP) Contributor client.
The TM1 Contributor client is using the TM1 Contributor Rich Client (RCP) framework.
The EP Contributor client is using the EP Contributor Rich Client (RCP) framework.
When you install both Contributor clients on the same computer, you must install the TM1 Contributor RCP framework before you install the EP Contributor RCP framework, see the IBM Technote 1454803 ->
http://www-304.ibm.com/support/docview. ... wg21454803
Unable to install TM1 Rich Client on computer which already has Planning 8.4 FP2 Rich Client
