Unload Cube
Posted: Thu Feb 23, 2012 5:13 am
by appleglaze28
A simple question for the TM1 Experts here I'm sure...this is my first time trying on the 'Unload Cube'...how do I undo this to get my values other than restarting my TM1 Data Server?
Re: Unload Cube
Posted: Thu Feb 23, 2012 5:43 am
by kpk
Resave the rule of this cube and all other cube rules sending feeders into this cube.
Re: Unload Cube
Posted: Thu Feb 23, 2012 5:54 am
by Gregor Koch
If you have no other cubes feeding this cube, a simple double click on the cube/opening a view on this cube should achieve the same.
Re: Unload Cube
Posted: Thu Feb 23, 2012 7:48 am
by appleglaze28
Tried both your suggestion and it doesn't seem to work.
Re: Unload Cube
Posted: Thu Feb 23, 2012 12:06 pm
by kpk
appleglaze28 wrote:Tried both your suggestion and it doesn't seem to work.
Do you use the rule editor?
Then in order to really resave the rule first you have to modify it.
A "space" char is enough.
HTH
