Unload Cube
appleglaze28
Unload Cube
Post by appleglaze28 »
A simple question for the TM1 Experts here I'm sure...this is my first time trying on the 'Unload Cube'...how do I undo this to get my values other than restarting my TM1 Data Server?
kpk
OLAP Product: TM1, CX
Re: Unload Cube
Post by kpk »
Resave the rule of this cube and all other cube rules sending feeders into this cube.
Best Regards,
Peter
Gregor Koch
OLAP Product: Cognos TM1, CX
Version: 9.0 and up
Excel Version: 2007 and up
Re: Unload Cube
Post by Gregor Koch »
If you have no other cubes feeding this cube, a simple double click on the cube/opening a view on this cube should achieve the same.
appleglaze28
Re: Unload Cube
Tried both your suggestion and it doesn't seem to work.
kpk
Re: Unload Cube
Post by kpk »
appleglaze28 wrote:Tried both your suggestion and it doesn't seem to work.
Do you use the rule editor?
Then in order to really resave the rule first you have to modify it.
A "space" char is enough.
HTH
Best Regards,
Peter
