Changing Default Actions for TM1 Workflow...
Posted: Tue Feb 14, 2012 6:46 pm
by tkingcka
Does anyone know how to change the java code to change the default actions of a delegator, owner, etc. to not show the revoke capability?
Re: Changing Default Actions for TM1 Workflow...
Posted: Fri Feb 17, 2012 12:22 pm
by oliver sullivin
You shouldn't need to change the java code, you can edit the actions and status relationships in the workflow admin area and even add new statuses and actions.
Posted: Wed Feb 22, 2012 1:22 pm
by tkingcka
Oliver-thank you for your comment. I did try what you suggested initially, but it did not change the default actions. I was told by another person I needed to change the java code to make it work with specific defaults. I have a friend that updated the scripts to make this change. I just thought there would be an easier way to make this possible. If you have any additional suggestions, please feel free to provide them to me.
TK
Posted: Fri Apr 13, 2012 3:21 pm
by AlexanderZ
Did changes in java code helped and where you (or your friend) have made them?
Thanks in advance.
