Changing Default Actions for TM1 Workflow...
- Excel Version: 2013
Does anyone know how to change the java code to change the default actions of a delegator, owner, etc. to not show the revoke capability?
Re: Changing Default Actions for TM1 Workflow...
You shouldn't need to change the java code, you can edit the actions and status relationships in the workflow admin area and even add new statuses and actions.
Oliver-thank you for your comment. I did try what you suggested initially, but it did not change the default actions. I was told by another person I needed to change the java code to make it work with specific defaults. I have a friend that updated the scripts to make this change. I just thought there would be an easier way to make this possible. If you have any additional suggestions, please feel free to provide them to me.
TK
TK
- Version: 10.1 10.2.1
- Excel Version: 2007 2010
Did changes in java code helped and where you (or your friend) have made them?
Thanks in advance.
Thanks in advance.
Alexander Z.
Alexander Z.
