Contributor security access
cdhodge2002
Post by cdhodge2002 »
All,
I am having an issue where non admin users are having the ability to edit and enter data in a certain tab of a contributor application without taking ownership of a tab. This tab does include the workflow dimension and in other tabs in the app the contributor security is working as designed. Does anybody know what might be causing this lack of security.
sander
OLAP Product: tm1
Re: Contributor security access
Post by sander »
Hello, I've had this problem also. In my case I had cell security defined for the cube which the view was based on. When I turned cell security of, contributor behaved 'normal' again.
Grtz Sander
pobrouwers
OLAP Product: IBM Cognos TM1
Version: 9.5.2
Excel Version: 2003-2007
Post by pobrouwers »
I've exactly same issue with you but I don't have any cell cube security in my app.
Do you have solve this issue ?
Thank you in advance for your reply
PO
