All,
I am having an issue where non admin users are having the ability to edit and enter data in a certain tab of a contributor application without taking ownership of a tab. This tab does include the workflow dimension and in other tabs in the app the contributor security is working as designed. Does anybody know what might be causing this lack of security.
Contributor security access
- OLAP Product: tm1
- Version: 10.2
- Excel Version: 2013
Re: Contributor security access
Hello, I've had this problem also. In my case I had cell security defined for the cube which the view was based on. When I turned cell security of, contributor behaved 'normal' again.
Grtz Sander
Grtz Sander
- Version: 9.5.2
- Excel Version: 2003-2007
I've exactly same issue with you but I don't have any cell cube security in my app.
Do you have solve this issue ?
Thank you in advance for your reply
PO
PO
