How to use both HIERARCHIZE and TM1 sort together in MDX
Gurumadheshwaran
Version: 9.5.1 and 9.5.2
Post by Gurumadheshwaran »
I am having an dimension with the following structure
All
Aaaa
Bbbbb
Ccccc
Ddddd
It has one parent and all leaf elements
I want the elements to be sorted in descending order with the hierarchy retained(the parent element retained)
I used the following MDX
{ HIERARCHIZE( {TM1SORT( {TM1SUBSETALL( [SubsetName] )}, DESC)} ) }
But it is not working, May i know whether the hierarchize and sort will work together or wont, if not is there any other solution to get this
Guru
Re: How to use both HIERARCHIZE and TM1 sort together in MDX
{[All]}+{TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 0)}, DESC)}
Gurumadheshwaran
tomok wrote:{[All]}+{TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 0)}, DESC)}
Thanks tomok,
It worked good, but i complexed it using UNION :D
{UNION({TM1FILTERBYLEVEL( {TM1SUBSETALL( [Dim_name] )}, 1)},
{TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [Dim_name] )}, 0)}, DESC)})}
Thanks again :)
MarenC
Excel Version: Excel 2016
Post by MarenC »
from a technical point of view why do I need the curly braces around All but not around the TM1Sort?
{[All]} + TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 0)}, DESC)
Union({[All]}, TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 0)}, DESC))
Maren
A function that returns a set, does not need additional { } around them.
If, for example, an element is strung together by text, that text needs to be converted into a set (of 1 element here) so it needs { }
