I am having an dimension with the following structure
All
Aaaa
Bbbbb
Ccccc
Ddddd
It has one parent and all leaf elements
I want the elements to be sorted in descending order with the hierarchy retained(the parent element retained)
I used the following MDX
{ HIERARCHIZE( {TM1SORT( {TM1SUBSETALL( [SubsetName] )}, DESC)} ) }
But it is not working, May i know whether the hierarchize and sort will work together or wont, if not is there any other solution to get this
Guru
How to use both HIERARCHIZE and TM1 sort together in MDX
Gurumadheshwaran
- Version: 9.5.1 and 9.5.2
Re: How to use both HIERARCHIZE and TM1 sort together in MDX
{[All]}+{TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 0)}, DESC)}
Gurumadheshwaran
tomok wrote:{[All]}+{TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 0)}, DESC)}
Thanks tomok,
It worked good, but i complexed it using UNION
{UNION({TM1FILTERBYLEVEL( {TM1SUBSETALL( [Dim_name] )}, 1)},
{TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [Dim_name] )}, 0)}, DESC)})}
Thanks again
MarenC
- Excel Version: Excel 2016
from a technical point of view why do I need the curly braces around All but not around the TM1Sort?
{[All]} + TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 0)}, DESC)
Union({[All]}, TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 0)}, DESC))
Maren
Maren
A function that returns a set, does not need additional { } around them.
If, for example, an element is strung together by text, that text needs to be converted into a set (of 1 element here) so it needs { }
