Problem Creating Groups in Cognos express.
Posted: Thu Dec 22, 2011 9:28 am
by karan2345
I am creating a contributor application and I have created some groups in Cognos.
Now there are some groups which shows 'Cognos\GroupName'
and the others shows only GroupName
When i give rights to the group consisting 'Cognos\GroupName' and save it shows right saved successfully. However if i save against the group which shows GroupName it gives me error that rights cannot be saved.
Please help.
Re: Problem Creating Groups in Cognos express.
Posted: Thu Dec 22, 2011 1:55 pm
by jim wood
This will depend on the level of security set in the CFG file. The groups without the prefix were (I'm guessing) created before you hooked up CAM security. I would stick to teh groups with prefix it will make your life easier.
Posted: Thu Dec 22, 2011 8:52 pm
by Martin Ryan
If your'e planning on using Contributor then you'll need to use the prefix, otherwise it fails.
Martin
