Hi everyone,
http://www.tm1forum.com/viewtopic.php?p=11179
Follow up on the discussion on the above link i know there is nothing TM1 cant do. But more like i would like to find out if anyone has similar experience to share in using TM1 to create a model that is used across different subsidiary of a company ? eg company A is a parent company of X, Y and Z. X, Y and Z are having different business model. So X, Y and Z will have their own cubes on the same server. Have you created a consolidation statement on group level ( Company A ) in TM1 ? If you have, how will you handle consolidation journal adjustment ?
TM1 model across multiple company
Re: TM1 model across multiple company
winsonlee,
I haven't done this in a while but when I was developing a model a couple of years ago we did have a few subsidiaries on one instance of TM1.
We simply had them rule driven into an Income Statement and SoFP cube with each going to an "Entity" element within a "Subsidiaries" dim.
There was another dimension which actually had a couple of dozen elements but for all intensive purposes it had "actuals" (which were loaded from the individual models), then there was a "JNL" element which was used to load in the contras (they were loaded via an excel workbook which had validations to make sure both sides of journals were entered etc. of course you could now make this prettier with active forms and TM1 web... possibly). Then obviously there was another element "result" which consolidated the original values with those that were journalled.
Whatever way you choose to go about this; the actual concept is pretty standard to TM1 with consolidations being fairly easy.
If you are worried about people from different locations accessing the same service then you simply need to put TM1 on a box that can be accessed from multiple sites (obviously your IT dept should be able to advise on this.)
If I have missed the point and there is a specific issue that you have regarding this, just elaborate further and I will see if I have come across something similar.
- Version: IBM SaaS - Digital Pack
Or an entirely different approach - Keep journal adjustments away from TM1 entirely and have a consolidation entity in the ledger system (the data from which is loaded into TM1).
You may find this is prefered by your finance / audit team
Don't forget Quebit's TM1 extension which allows journalling linked to TM1:
http://www.quebit.com/SCOPE-for-TM1.asp
I've implemented a predecessor product and found it rather good, especially as regards plugging it into your (sensible) custom TM1 design.
