TI process should not load data if it throws error
swati_phadtare
Version: 9.5
Excel Version: 200
Post by swati_phadtare »
Hi ,
While loading data from flat file through TI process if it throws any error then it should not load any data to cube.
Kindly help me in coding this.
Thanks & Regards
Re: TI process should not load data if it throws error
Your best bet is to trap "any errors" in the metadata tab before starting the data tab. Then if you find errors you can processbreak/quit at the end of the metadata.
Christopher Kernahan
Excel Version: Office 2010
For individual items that have errors, you can use ItemReject('message'); which will skip the particular data line and also output a message to the Message Log.
Post by David Usherwood »
If you don't want _any_ data from the feed to be left in the cube, count the errors and clear the destination in the epilogue if the count is positive.
