Hi ,
While loading data from flat file through TI process if it throws any error then it should not load any data to cube.
Kindly help me in coding this.
Thanks & Regards
TI process should not load data if it throws error
- Version: 9.5
- Excel Version: 200
- Steve Rowe
Re: TI process should not load data if it throws error
Your best bet is to trap "any errors" in the metadata tab before starting the data tab. Then if you find errors you can processbreak/quit at the end of the metadata.
- Version: 10.1
- Excel Version: Office 2010
For individual items that have errors, you can use ItemReject('message'); which will skip the particular data line and also output a message to the Message Log.
If you don't want _any_ data from the feed to be left in the cube, count the errors and clear the destination in the epilogue if the count is positive.
