Sandbox disabled in TM1 Contributor
Posted: Wed Jul 27, 2011 8:19 pm
by tryinghard
The sandbox is disabled in a TM1 contributor applications that I have created. It is enabled in TM1 Web and perspective. Even in the design mode of TM1 Contributor, the property "Enable Multiple Sandboxing" is said to Yes. Any clue what else I could be missing?
Re: Sandbox disabled in TM1 Contributor
by tryinghard
I have taken ownership and even then this problem persists.
Posted: Thu Jul 28, 2011 4:11 pm
by tryinghard
Anybody, any knowledge on this?
Posted: Thu Jul 28, 2011 5:51 pm
by tomok
At least you're living up to your screen name. :P
Posted: Thu Jul 28, 2011 11:48 pm
by Martin Ryan
Have you checked the capability assignments on the server? (Right click on the server name and go to "Capability Assignments"). By default users can use the sandbox, but it maybe that this got turned off for some reason.
Martin
Posted: Fri Jul 29, 2011 8:44 am
by Carl E
I've experienced the same thing in Contributor 9.5.2, when upgrading from 9.5.0. The Sandbox works perfectly fine in Architect or Perspectives but not in Contributor. The "Capability Assignments" are blank on sandboxing, Sandboxing is also enabled in Contributor Administration, ownership is taken..
Posted: Tue Mar 05, 2013 3:32 am
by jameswebber
