The sandbox is disabled in a TM1 contributor applications that I have created. It is enabled in TM1 Web and perspective. Even in the design mode of TM1 Contributor, the property "Enable Multiple Sandboxing" is said to Yes. Any clue what else I could be missing?
Sandbox disabled in TM1 Contributor
tryinghard
- Version: 9.5.1
- Sandbox.jpg (6.79 KiB) Viewed 6390 times
tryinghard
- Version: 9.5.1
Re: Sandbox disabled in TM1 Contributor
I have taken ownership and even then this problem persists.
tryinghard
- Version: 9.5.1
Anybody, any knowledge on this?
At least you're living up to your screen name.
- Martin Ryan
Have you checked the capability assignments on the server? (Right click on the server name and go to "Capability Assignments"). By default users can use the sandbox, but it maybe that this got turned off for some reason.
Carl E
- OLAP Product: Cognos BI
- Version: 9.5.2
I've experienced the same thing in Contributor 9.5.2, when upgrading from 9.5.0. The Sandbox works perfectly fine in Architect or Perspectives but not in Contributor. The "Capability Assignments" are blank on sandboxing, Sandboxing is also enabled in Contributor Administration, ownership is taken..
- jameswebber
- OLAP Product: Cognos Express 10
- Version: CE 10.1.1
