Rules Security
Posted: Fri Jul 15, 2011 8:03 am
by nimol
I need to apply security to rules, i.e. users should not be able to see cube rules and not be able to amend them. How do you achieve that?
Re: Rules Security
Posted: Fri Jul 15, 2011 9:31 am
Users cannot ammend rules. Only administrators are able to edit rules.
However as far as I am aware there is no way to suppress the display of rules under the cubes. (and even if you could a user can always click on "trace calculation" in the cube viewer and see the rule that is in effect.)
Re: Rules Security
Posted: Fri Jul 15, 2011 9:58 am
by qml
More specifically, you need at least READ access to a cube to view its rules and at least ADMIN access to a cube to edit rules. You do not have to be a member of any of the 3 standard "Admin" groups.
Re: Rules Security
Posted: Fri Jul 15, 2011 2:34 pm
by nimol
Thanks for explanation. Talking about disabling functions, are you are able to disable menu choice "display control objects" for users?
